THUMP3RZ
Feb 07, 2022Aspirant
Nighthawk AC1900 intermittent drops offline
My AC1900 R7000 has been connected to a new fiber modem with 200/200 upload/downloads. I use it heavily and WiFi only. It has been intermittently dropping offline where I have to pull up my app and ...
- Feb 07, 2022
THUMP3RZ wrote:
The Nighthawk app says there is no update available. Now the website says there is. I tried doing the update manually via the web but it doesn't work like it should and the website says to use the app. I guess I will just limp along
Do you have screen snips of the errors/problems you're running into?
I frequently use the browser to update.
