DJM200
Dec 12, 2016Aspirant
Nighthawk AC1900 Model R7000 troubles
Hello
EAch time i turn on my computer which is wired to the router I get an error message "Control Center Installation is incompleter Please reinstall again"
It had been working just fine and all of sudden this appear .
Is it an issue ? What do I do to fix it .
my Firmware Version is V1.0.7.2_1.1.93
When I went to check on the firmware update it said there was firm ware V1.0.1.22-1.0.15 zip availble. hmmm.
I think this is an older version than I already have , is that correct?
HOw do I fix this pop up
Thanks for any help .I am not the greatest with these things
Doug
Well done. As suspected, it was not really the R7000 but the stuff surrounding it.
Did you try reinstalling the newer version after you cleaned out the old one?
The message you saw sounds like something wonky in the setup. Now that you have sorted that out, perhaps installing it afresh would work.
Start from scratch, and do everything that you need to do to add the printer and see if that works.
At least you know how to recover if that does not give you control over the printer.
Or start another discussion about getting the printer to work. This one could mislead people because it is about mysterious popups.
Is there anything that tells you that this is a router issue?
Google suggests that any number of factors could be involved.
A local search also shows that this has also come up hare before:
Control Center Installation - NETGEAR Communities
- DJM200Aspirant
The pop up message I get is titled Netgear USB control center and the message is Control cente installation is incomplete Please reinstall. I comes up each time I turn on the computer. so I guess it is related to the router.
What about the stuff mentioned in the other discussion that I linked to?
