DJM200
Dec 11, 2016Aspirant
Nighthawk AC1900 Model R7000 troubles
Hello EAch time i turn on my computer which is wired to the router I get an error message "Control Center Installation is incompleter Please reinstall again" It had been working just fine and all ...
- Dec 16, 2016
Well done. As suspected, it was not really the R7000 but the stuff surrounding it.
Did you try reinstalling the newer version after you cleaned out the old one?
The message you saw sounds like something wonky in the setup. Now that you have sorted that out, perhaps installing it afresh would work.
Start from scratch, and do everything that you need to do to add the printer and see if that works.
At least you know how to recover if that does not give you control over the printer.
Or start another discussion about getting the printer to work. This one could mislead people because it is about mysterious popups.
michaelkenward
Dec 16, 2016Guru - Experienced User
DJM200
Dec 17, 2016Aspirant
I deleted it and reloaded and it and no pop up.
So I decided to load netgear usb controller app to see if I could get the printer working through the router
the app in there on the computer wired to the router and t he lap top but the printer is not seen by the app either.
So have made progress with your help
thank you very much
I will start a new thread about this .
Thanks for your help
