lancewo
Dec 20, 2020Guide
Nighthawk ac1900 r6900
Hi, I've been using this Nighthawk AC1900 Smart Wifi Router and I love the Readyshare USB functionality. Recently Comcast provided me a faster modem/router but it doesn't have the readyshare capabi...
- Dec 20, 2020
> Model: R6900|Nighthawk AC1900 Smart WiFi Router
R6900[v1] or R6900v2? Look for "Model" on the product label.
Firmware version?Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for a topic like
"Use the Router as a WiFi Access Point".Note that when you do that, the R6900[vX] will get a new/different
LAN IP address, which might change the way you access it (specifying its
IP address instead of some "routerlogin" or "readyshare" name).It would probably be wise to reserve some particular address for the
R6900[vX]-as-WAP on your (unspecified) "Comcast's modem/router", so that
the R6900[vX]-as-WAP always gets the same address. Check the
documentation on that device for details. I'd look for terms like
"DHCP" or "address reservation".
antinode
Dec 20, 2020Guru
Firmware version?
lancewo
Dec 21, 2020Guide
Antinode (Guru) - Thank you so much. I was able to modify the mode on my Nighthawk from Router to AP (Access Point) through Advance Setup. Now I'm able to utilize their Readyshare functionalities. It worked great. Thank you again for your help!!
