as1020
Mar 05, 2022Follower
Nighthawk AC1900 R6900P
Dear all, I'm a student moved to Puerto Rico using an interet service called Liberty Internet. The internet range is not that strong and I'm currently using a TP-Link AC1750 extender. This helps ...
Kitsap
Mar 05, 2022Master
When you connect an ethernet cable between the Arris TG2482 and the Netgear R6900 it should work with the R6900 configured as a wired access point. The ethernet cable has to connect from one of the LAN ports on the TG2482 to the WAN port on the R6900.
