keinpesto's avatar
keinpesto
Follower
Dec 30, 2021
Nighthawk AC1900 R700 question
I bought an AC1900 and connected to my modem and set it up. I then unplugged it from the modem to move to my office (cable connection doesn’t work in my office so I can’t move the modem). My office does have a phone line that my printer is hooked up to, but there are no Ethernet ports anywhere in my house.
I was under be impression that I could use the AC1900 as an internet extender to connect to my desktop to the Nighthawk via Ethernet, as there is nowhere else to connect my desktop in this room. Did I get the wrong device? Can I hook my nighthawk into the phone line? Does the AC1900 always have to be hard ported into the Modem?
1 Reply
  • plemans's avatar
    What modem do you have?
    Some are modem/router combo devices.
    If its strictly a modem only device, then you need the router hardwired into it.
    If its a modem router combo device, then potentially some routers have extender/repeater mode you could connect it with.
    You have the R7000?
    What firmware is on it?
