Localjoost
Jan 24, 2016Aspirant
Nighthawk AC1900 R7000 2.4Ghz not connecting
I have a Nighthawk AC1900 R7000 * 5GHz works for my Internal Wifi network and for the Guest network * 2.4Ghz only works for Guest Network I can see the 2.4Ghz SID, but all devices, after askin...
- AnonymousJan 24, 2016
revert to.4.30 or 4.28
Factory reset to defaults.....DO NOT use saved configuration
Delete or forget 2.4 previous connections in all devices
Anonymous
Jan 24, 2016revert to.4.30 or 4.28
- LocaljoostJan 30, 2016Aspirant
Thank you for this suggestion, you led me on the right path. One remark, though: I was a bit stubborn, and first 'updated' to 1.0.4.28. My problems were immediately solved. I could manually connect my phone to the 2.4Ghz network, and the Raspberry PI2 immediatly connected after booting. I have not factory reset my router (yet). And I think I won't, at least not while the PI2 keeps connecting, which was the whole point
