Localjoost
Jan 24, 2016Aspirant
Nighthawk AC1900 R7000 2.4Ghz not connecting
I have a Nighthawk AC1900 R7000 * 5GHz works for my Internal Wifi network and for the Guest network * 2.4Ghz only works for Guest Network I can see the 2.4Ghz SID, but all devices, after askin...
- Retired_MemberJan 24, 2016
revert to.4.30 or 4.28
Factory reset to defaults.....DO NOT use saved configuration
Delete or forget 2.4 previous connections in all devices
Localjoost
searay is that a known issue? How on earth is this possible? Been running the 5.48 for quite some time without problems :(
- Retired_MemberJan 25, 2016
Many have reported problems with the last two updates.
- JamesGLJan 25, 2016NETGEAR Employee Retired
Hi Localjoost,
Please check your inbox.
