Localjoost's avatar
Localjoost
Nighthawk AC1900 R7000 2.4Ghz not connecting
I have a Nighthawk AC1900 R7000  * 5GHz works for my Internal Wifi network and for the Guest network * 2.4Ghz only works for Guest Network   I can see the 2.4Ghz SID, but all devices, after askin...
  • Retired_Member's avatar
    Retired_Member
    Jan 24, 2016
    revert to.4.30 or 4.28
    Factory reset to defaults.....DO NOT use saved configuration
    Delete or forget 2.4 previous connections in all devices
