Localjoost
Jan 24, 2016Aspirant
Nighthawk AC1900 R7000 2.4Ghz not connecting
I have a Nighthawk AC1900 R7000 * 5GHz works for my Internal Wifi network and for the Guest network * 2.4Ghz only works for Guest Network I can see the 2.4Ghz SID, but all devices, after askin...
- Retired_MemberJan 24, 2016
revert to.4.30 or 4.28
Factory reset to defaults.....DO NOT use saved configuration
Delete or forget 2.4 previous connections in all devices
GaryN
Jan 25, 2016Aspirant
Basically the same issue for me. After updating to the current firmware (V1.0.6.28_1.1.83 ), the 2.4Ghz band shows strong signal strength, but after a day or two the clients connected to that band are unable to access the internet. The 5Ghz band works fine. Is Netgear planning on releasing a new firmware update soon. It's a little tedious rebooting the router every couple of days.
rpoffen
Jan 26, 2016Virtuoso
Don't reboot the router every couple of days, juse downgrade to the 1.0.4 firmware as someone else suggested. Then keep watching these forums for a new version and that it has been around for a while and doesn't have any problems before upgrading.
