Localjoost
Jan 24, 2016Aspirant
Nighthawk AC1900 R7000 2.4Ghz not connecting
I have a Nighthawk AC1900 R7000 * 5GHz works for my Internal Wifi network and for the Guest network * 2.4Ghz only works for Guest Network I can see the 2.4Ghz SID, but all devices, after askin...
- Retired_MemberJan 24, 2016
revert to.4.30 or 4.28
Factory reset to defaults.....DO NOT use saved configuration
Delete or forget 2.4 previous connections in all devices
Retired_Member
Jan 24, 2016revert to.4.30 or 4.28
Localjoost
Jan 30, 2016Aspirant
Thank you for this suggestion, you led me on the right path. One remark, though: I was a bit stubborn, and first 'updated' to 1.0.4.28. My problems were immediately solved. I could manually connect my phone to the 2.4Ghz network, and the Raspberry PI2 immediatly connected after booting. I have not factory reset my router (yet). And I think I won't, at least not while the PI2 keeps connecting, which was the whole point
