Steve_tanner
Jan 13, 2017Aspirant
Nighthawk AC1900 R7000 2.4ghz wifi not working
I'm running the most recent firmware V1.0.7.6_1.1.99. So my R7000 will broadcast 2.4ghz inconsistently, until none of my devices are able to connect to it. The devices will be "No internet, secured"....
- May 18, 2017
Hi kman68,
Reset the router to factory default and try to reconfigure it manually.
TheEther
Jan 13, 2017Guru
Have you tried changing the Wi-Fi channel? Perhaps the one in use is unusable due to too many neighboring networks or interference.
Steve_tanner
Jan 14, 2017Aspirant
I have tried that, actually. No change. Very few wifi connections around me anyways. Definitely not enough to interrupt my signal.
- TheEtherJan 14, 2017Guru
Try performing a factory reset.
- Steve_tannerJan 14, 2017Aspirant
If you refer to my original post, you'll see that I've already tried a number of factory resets. I feel quite confident another won't give me different results. I appreciate your input, though!
