Steve_tanner
Jan 13, 2017Aspirant
Nighthawk AC1900 R7000 2.4ghz wifi not working
I'm running the most recent firmware V1.0.7.6_1.1.99. So my R7000 will broadcast 2.4ghz inconsistently, until none of my devices are able to connect to it. The devices will be "No internet, secured"....
- May 18, 2017
Hi kman68,
Reset the router to factory default and try to reconfigure it manually.
disgusted_
Jan 15, 2017Aspirant
Steve,is right, my 2.4ghz never woks. Past time to return.
i have discovered that the model R7000 has the same problems. These were rated very high and many many users have the same problem. Netgear refuses to upgrade their FW. Class action suit is clearly in order, or if anyone wants to buy this worthless device let me know.
has anyone found a solution to this?
i have put in countless hours and may need to find another modem/wifi device
i
