Steve_tanner's avatar
Steve_tanner
Nighthawk AC1900 R7000 2.4ghz wifi not working
I'm running the most recent firmware V1.0.7.6_1.1.99. So my R7000 will broadcast 2.4ghz inconsistently, until none of my devices are able to connect to it. The devices will be "No internet, secured"....
  • JamesGL's avatar
    JamesGL
    May 18, 2017
    Hi kman68,
    Reset the router to factory default and try to reconfigure it manually.
