Steve_tanner
Jan 13, 2017Aspirant
Nighthawk AC1900 R7000 2.4ghz wifi not working
I'm running the most recent firmware V1.0.7.6_1.1.99. So my R7000 will broadcast 2.4ghz inconsistently, until none of my devices are able to connect to it. The devices will be "No internet, secured"....
- May 18, 2017
Hi kman68,
Reset the router to factory default and try to reconfigure it manually.
Steve_tanner
Jan 17, 2017Aspirant
Yes I have reflashed the most recent firmware a number of times, (their customer service advised me to do this as well) and I don't know which version it shipped with.
When I say I have done 'factory resets' I mean that I've gone into the router webpage and reset the router to factory defaults. But I've also used a paper clip to hold in the 'reset' button for 60sec to reset the routher that way too.
The reason I don't think it's broken is, prior to this I bought a comparable Asus router and had the exact same issue. I ended up taking it back a few days later and replacing it with the nighthawk. It's not impossible for both routers to have the exact same issue, but it kind of seems unlikely right?!
TheEther
Jan 17, 2017Guru
If two routers from different brands had the same issue, then it's very likely that the routers were not the problem. Instead, it's likely that the 2.4 GHz band is unusable in your area. You should run a Wi-Fi Analyzer program to survey what networks are around you. If you live in an apartment, for example, that would potentially be a worst case scenario.
- Steve_tannerJan 17, 2017Aspirant
I live in a neighbourhood in a rural town, so there are SOME other connections but the channels aren't really overcrowded. Most of them are unused in fact. It's worth noting that up until a few weeks ago when it fried, my old TP-Link duel band worked perfectly inspite of the other connections in my area.
- IrvSpJan 18, 2017Master
What OS are you running? Know it is windows, that is all you've shared.
Hardly likely to be a router problem as you stated the original router (TP-Link) worked fine but the replacement and the NG do not. That sort of points back to the individual network adapters IMHO.
It could be possible the network adapters are SET to always connect to the TP-Link SSID. Not there, they give up. Are you using a different SSID than the one you had on the TP-LINK? I guess you could try changing the NG wireless properties to match the old TP-Links SSID and passphrase.
Did you MANUALLY set the desired IP Address on the wireless device properties? If so they must be on the set network, 192.168.1.1 in your case.
In Windows you CAN reset the NETWORKs. Google "reset windows xx networking" substituting you windows version for 'xx' as there are different ways to do that in different versions.
