Steve_tanner
Jan 13, 2017Aspirant
Nighthawk AC1900 R7000 2.4ghz wifi not working
I'm running the most recent firmware V1.0.7.6_1.1.99. So my R7000 will broadcast 2.4ghz inconsistently, until none of my devices are able to connect to it. The devices will be "No internet, secured"....
- May 18, 2017
Hi kman68,
Reset the router to factory default and try to reconfigure it manually.
kman68
May 16, 2017Star
JamesGL wrote:Hi kman68,
What is the firmware version of the router? Make sure to update it.
https://kb.netgear.com/000038289/R7000-Firmware-Version-1-0-7-12
That is when it broke. Worked fine with last firmware. When I updated to the latest one is when it went bad along with lots of other people having the same issue. This is a Netgear firmware and genie problem. Not a user problem.
