iSeawitch
May 29, 2023Aspirant
Nighthawk AC1900 R7000 extremely slow on WIfi
So it all started with a problem with the line in the street and low upload speeds. That got fixed and now if I connect directly to Spectrums modem with the laptop I get 450+upload and 22 down. When...
- May 30, 2023
iSeawitch wrote:199 Mbps download speed using the laptop connected to the wifi .
450 Mbps when laptop is connected to the modem directly. Isn't that what you asked for initially?
Now that you have changed your network category from public to private, you need to go to your Laptop configuration and forget the previous Wi-Fi network connection. Reconnect over Wi-Fi and enter you Wi-Fi password from scratch.
For throughput testing, are you using the Ookla stand alone application for Windows? If not, go to the play store and install it. This eliminates the web browser application from the equation.
iSeawitch
May 30, 2023Aspirant
Hitron Docsis 3.1 p/n 1522300001v0
yes to pulling power and restarting in appropriate order.
yes to forgetting and re-adding the network with password
Im not seeing a private/public option.
V1.0.11.136_10.2.120Is that not the newest?
Thanks.
michaelkenward
May 30, 2023Guru - Experienced User
Change from Public to Private Network in Windows 7, 8 and 10
Windows 10 Tip: How To Change The Network Type From Public To Private | Bruceb News
It is.
- iSeawitchMay 30, 2023Aspirant
Changing to private brought it up some but still less than half of the connection to the modem directly.
- michaelkenwardMay 30, 2023Guru - Experienced User
Your subject says "extremely slow on WIfi".
How fast is it now?
Remember that wifi will always be slower than wired and the R7000 doesn't support newer "go fast" wifi standards. Compare the wifi clients you are using on different sources.
199 down on the router,, direct connect was 450.
