EdwardH
Oct 23, 2023Aspirant
Nighthawk AC1900 R7000 Firmware won't update by router, app or manually
When I log into my router it says my current firmware is v1.0.11.126, when I go to see if there are updates available the app and the router itself says there is nothing available, but on the Netgear...
microchip8
Oct 23, 2023Master
Define "not update". What actually happens when you do it? What messages, if any, do you get?
- EdwardHOct 23, 2023Aspirant
- microchip8Oct 24, 2023Master???
- EdwardHOct 24, 2023Aspirant
Manually it runs through the firmware update... reboots but then still has the same firware version. No message no nothing.
- michaelkenwardOct 24, 2023Guru - Experienced User
EdwardH wrote:
Manually it runs through the firmware update... reboots but then still has the same firware version. No message no nothing.It can help to reset the firmware before you install the new version.
You could also try one of the intermediate versions before the latest.
