djbiehl6
Jun 13, 2019Aspirant
Nighthawk AC1900 R7000 Slow Hardwired Speed
Router Model: Nighthawk AC1900 Smart Wifi Router Model R7000 PC: Intel gigabit ethernet adapter (up to 1000mbps) The new pc I built does not have a wifi card built in so all I have is ethernet h...
- Jun 13, 2019
Latest from app does not give me a number. I am not a mind reader.
Also have you tried reset and reconfigure? That would probably be the next step as you probably have auto update on and the router was updated without your knowledge.
myersw
Jun 13, 2019Master
First question is what version of firmware are you running, number not something like latest.
What steps have you taken to try to fix?
Things like reset the router and reconfigure. Know that is a pain, but does fix issues, especially if new firmware install. Things like auto update on can cause issues as you are not aware that a firmware update has happened.
- djbiehl6Jun 13, 2019Aspirant
myersw wrote:First question is what version of firmware are you running, number not something like latest.
Bill,I checked my latest firmware from the nighthawk app yesterday and it said it was up to date already. I restarted my modem and router and couple times yesterday when trying to troubleshoot the issue.
- myerswJun 13, 2019Master
You might want to read this thread. Folks having issues similar to yours and some suggestions as to possible firmware to try. I am assuming you are on the .64 firmware since that is "latest".
