djbiehl6's avatar
djbiehl6
Nighthawk AC1900 R7000 Slow Hardwired Speed
Router Model: Nighthawk AC1900 Smart Wifi Router Model R7000 PC: Intel gigabit ethernet adapter (up to 1000mbps)   The new pc I built does not have a wifi card built in so all I have is ethernet h...
  • myersw's avatar
    myersw
    Jun 13, 2019
    Latest from app does not give me a number. I am not a mind reader.
    Also have you tried reset and reconfigure? That would probably be the next step as you probably have auto update on and the router was updated without your knowledge.
