MacSam's avatar
MacSam
nighthawk AC1900 R7000 wireless button switched off
Hi, WIFI was lost whilst watching TV. Several hours later it was discovered that the wireless had been switched off and could only be switched on until the wireless button was switched on. How can th...
  • MacSam's avatar
    MacSam
    Nov 15, 2021
    I did not know trhe switch existed. When I eventualy checked if the wireless was on, the box was ticked to say it was enabled but greyed out with the words added to the effect telling me that it needed to be switched on at the button. I copied and pasted that to search in the manual but nothing came up. I checked the router and saw the button. It came on then.
    I did switch the wireless off on Wednesday in advance settings for a brief period and switched it back on again at the same place. Perhaps it was a hangover from that? I have had the router for 18 months and have never switched the wireless off during that period prior to that day.
    Thank you for your response. I do feel a bit better about the 'hack' now.
