danap46
Nov 27, 2020Follower
Nighthawk AC1900 WIFI Extender Model EX7000
I plugged in my Netgear Extender and cannot see NETGEAR_EXT network under my available networks to connect my router to the Netgear Extender - any suggestions.
Thanks, David
1 Reply
do you know what firmware is on your extender?
Did you try to set it up using WPS? If so and its on a more recent firmware, it'll setup in mesh mode. Meaning it'll use the same ssid as the router.
What are the led's on it showing?
