Patricklewis82
Jul 11, 2023Aspirant
Nighthawk ac1900
My router quit putting out wifi. So all lights are on as they should be. Firmware is up to date, 30-30-30 rest has be done, and there is an address from the modem. It just will not put out internet co...
Jul 11, 2023Guru - Experienced User
Try a 10 second press on the reset button in back then release. Setup from scratch using a wired PC and web browser connected at 192.168.1.1
What is the model # of this router? R####?
Patricklewis82
Problem is I don’t have a plug in desktop. I cannot do that type of set up. Everything is wifi.
- Patricklewis82Jul 11, 2023AspirantI went through the new set up through the app and it has not internet connect, it’ll detect the router but won’t connect to the internet
- FURRYe38Jul 12, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.Has a power off for 1 minute then back ON with the ISP modem and router been performed?
Turn off and unplug modem.
Turn on computers and rest of network.- Patricklewis82Jul 19, 2023AspirantDid all that previously, my dad ended up getting a new router. Everything worked just fine. I brought his old one home to figure it out. I’ll hook it up to my network and see if it works.
