jsemle
Aug 07, 2021Aspirant
NightHawk AC2100 - Crashing and Resetting
I've been struggling with my AC2100 for the past couple days. It worked perfectly for about 2 years, and has now started crashing constantly. Every time it boots up it factory resets itself, losing m...
jsemle
Thanks! I don't think I do, but I'll look into buying one if this problem persists. I'd much rather replace a faulty power supply than the whole router.
Aug 07, 2021Guru - Experienced User
Might not be worth buying one as if its not the power supply, then you might have been better off saving the $ for an upgrade on the router.
That's why I usually have people dig around a bit and see if they have something matching.
