elCHeeliTO
Feb 11, 2021Tutor
Nighthawk AC2300 - Disconnects Every 2 hours and 4 minutes
My new Nighthawk AC2300 - Disconnects Every 2 hours and 4 minutes, I run a streaming quote program and that's how I'm able to tell, every time connection is interrupted I get a warning with the exact...
Feb 12, 2021Guru - Experienced User
What firmware version are you on?
What modem are you connecting it to?
is it all devices dropping, just wired device, just wireless devices?
elCHeeliTO
Feb 12, 2021Tutor
Firmaware is up to date: V1.3.1.64_10.1.36
Modem: Netgear CM1000 DOCSIS 3.1 Cable Modem
Wired PC dropping only as far as I know
- plemansFeb 12, 2021Guru - Experienced User
And its happening only to wired device? usually you see it with wireless devices.
2 things you can try. and the order i'd try them in.
1. Install version 1.3.2.134 of the firmware to it over a hardwired connection (in case the firmware is corrupt), then do a factory reset and clean install (not from a backup in case that's corrupt).
2. if that doesn't work, try downgrading to version 1.3.0.20 of the firmware. follow the same install over hardwired connection/factory reset/clean install. The newer versions have netgear armor and maybe yours doesn't play nicely with armor.
- elCHeeliTOFeb 12, 2021Tutor
I 'll give that a try when I have some time to spend on it, but, I am really curious and maybe you know the answer, why is it that when I check for new firmware from the router interface, it says "No new firmware version available." ?
Not sure exactly why. I've seen it quite frequently with the R7000P and the R7000
