Wiedmann
May 02, 2020Aspirant
Nighthawk AC2300 - R7000P - Extremely slow speeds on an iPhone X
Hi, I setup a new R7000P router, and I seem to be having a significant problem with the connection/speed on my iPhone X. As seen in the attached screenshot phone_link_rate_marked.PNG from the Ni...
- May 24, 2020
Great news! Everything is now working at top speed for both my iPhone and my laptop with Smart Connect enabled.
After resetting the router 5-10 times and switching on/off Smart Connect 3 times over a period of a month, it seems like the router has learned to maximize bandwidth for both my computer and phone.
Based on these other posts with similar smart phone issues: Nighthawk R7000P speeds extremely slow and Mobile devices slow on Nighthawk R7900 which seemed to eventually be resolved later, I'm thinking there is probably some bug with the router upon initial installation in relation to smart phone bandwidth, but after things are reset and switched around enough it gets into a normal state.
Either way it is fixed now, so I'm happy!
May 03, 2020Guru - Experienced User
Are you using smart connect?
Because it shows you connected to the 2.4ghz band. Its more sensitive to interference. have you been able to connect the iphone to the 5ghz band?
Wiedmann
May 03, 2020Aspirant
Thanks for the reply plemans.
That's a good question. Indeed I am using Smart Connect and my HP laptop was automatically connected to 5GHz while the iPhone was connected to 2.4GHz. I figured this wasn't the issue since I assumed the way Smart Connect should work it should automatically flip to the faster frequency band, correct?
I went ahead and disabled Smart Connect and manually connected the phone to the 5GHz network, and indeed now I get the top speed.
However, this doesn't seem to be the whole story since I also manually connected my HP laptop to the 2.4GHz network with Smart Connect disabled and while I didn't get the top speed it still clocked in at 25.47 Mbps down (20% of top) and 6.56 Mbps up (full speed) which is still an order of magnitude faster than what I am getting on my phone on 2.4GHz. Maybe this is just explained by a weaker wireless network card in the phone vs the laptop?
Long story short, with Smart Connect enabled why would the iPhone not automatically switch to the 5GHz network if this frequency band has less interference?
Thanks
- plemansMay 04, 2020Guru - Experienced User
So the auto switching isn't right away. It might switch right when it notices the demand but from my experience its more based on user history. My devices I constantly stream on, it learns to place on the 5ghz. my lower bandwidth devices will stay on 2.4ghz until they've been repeatedly using a lot of bandwidth. It makes sense if you think about it. When a device requests data from the router, it sends the most it can handle. If it had to take into account this fact, every device would be getting put on the 5ghz because it'd be maxing out the signal right away. so it has to figure out a rough average of how much data a device uses and not peak data useage.
have you tried changing 2.4ghz channels on the router to see if it'd help the phone?
- WiedmannMay 05, 2020Aspirant
I have not tried changing the channels; I just have it set to the default of Auto for the 2.4Ghz. Shouldn't this setting automatically select the best channel and automatically change if needed?
For a manual test like your suggesting are there certain channels you suggest I try, or it doesn't matter and it is just the luck of the draw which ones might be better than others?
Thanks again for the response.
- plemansMay 06, 2020Guru - Experienced User
for the 2.4ghz, I'd keep it on auto.
For the 5ghz, you can actually download a free scanner app and scan to see whats broadcasting on the 5ghz. i usually use inssider or acrylic. Once you can see what channels are least congested, just choose those from the channels available.
