Wiedmann
May 02, 2020Aspirant
Nighthawk AC2300 - R7000P - Extremely slow speeds on an iPhone X
Hi, I setup a new R7000P router, and I seem to be having a significant problem with the connection/speed on my iPhone X. As seen in the attached screenshot phone_link_rate_marked.PNG from the Ni...
- May 24, 2020
Great news! Everything is now working at top speed for both my iPhone and my laptop with Smart Connect enabled.
After resetting the router 5-10 times and switching on/off Smart Connect 3 times over a period of a month, it seems like the router has learned to maximize bandwidth for both my computer and phone.
Based on these other posts with similar smart phone issues: Nighthawk R7000P speeds extremely slow and Mobile devices slow on Nighthawk R7900 which seemed to eventually be resolved later, I'm thinking there is probably some bug with the router upon initial installation in relation to smart phone bandwidth, but after things are reset and switched around enough it gets into a normal state.
Either way it is fixed now, so I'm happy!
Wiedmann
May 24, 2020Aspirant
