Tall-Eric
Feb 20, 2020Tutor
Nighthawk AC2300 firmware update fails
It current has firmware version 1.3.1.26 and Nighthawk mobile app informs me an update to 1.3.1.64_10.1.36 is avaialble. I ask it to install, the app says it completes and reboots, but then I get the...
- Feb 20, 2020
I would try manually doing the update. download the update, extract it, and then follow the manual install instructions from the manual.
I also recommend doing the update over a hardwired connection for the best results.
Ac2300 isn't a speed but based upon the firmware you posted, you probably have the R7000P?
here's where you'd get the firmware and manual.
https://www.netgear.com/support/product/R7000P.aspx
Feb 20, 2020Guru - Experienced User
Tall-Eric
Feb 23, 2020Tutor
thank you, that worked! Much appriciated
