Krod-Nov's avatar
Krod-Nov
Nighthawk ac2300 Lan speed limited to 100mbps
I connected a Synology NAS 220+ and it only connects at 100mbps, how can I get it to connect at 1000mbp?
  • Krod-Nov's avatar
    Krod-Nov
    Nov 09, 2021
    It was the cable, I bought a CAT7 cable on Amazon and that is what I was using. I changed it to a CAT6 cable and I am now getting the 1000 MEG speeds. Thank you for your help
