SpaceGoat
Sep 14, 2021Follower
NightHawk AC2300 no internet and no router connectivity
Nighthawk 3 month old, went to move the location of the router and modem, and now the router refuses the internet from the modem. Modem is Spectrum ET2251 and when I hook up my Spectrum supplied rou...
Sep 14, 2021Guru - Experienced User
Did you power OFF both ISP Modem and router for 1 minute then back ON with the modem first then router?
Be sure your using good quality Lan cables. CAT6 is recommended.
