RussF57's avatar
RussF57
Nighthawk AC2300 R7000 - should antennas be returned with an approved RMA?
Are the detachable antennas considered part of the router or are they considered "accessories"? I am not sure if I should pack it with the router for RMA. The instructions on the return policies page...
  • shadowsports's avatar
    Dec 17, 2018
    Greetings,
    The antennas are not considered accessories.  You typically keep everything except the router and antennas, even if they can be detached.
