RussF57
Dec 17, 2018Aspirant
Nighthawk AC2300 R7000 - should antennas be returned with an approved RMA?
Are the detachable antennas considered part of the router or are they considered "accessories"? I am not sure if I should pack it with the router for RMA. The instructions on the return policies page...
- Dec 17, 2018
Greetings,
The antennas are not considered accessories. You typically keep everything except the router and antennas, even if they can be detached.
shadowsports
Dec 17, 2018Hero
Greetings,
RussF57
Dec 18, 2018Aspirant
Thanks for your help !
Russ
