DarciM
Mar 01, 2022Aspirant
Nighthawk AC2300, R7000P; WiFi/SSID not broadcasting, all lights on, all settings set to ON
I purchased this router used (so that may admittedly be problem 1...). Netgear Nighthawk AC2300, R7000P. I have it for a small office in a large building with fiber internet so there are multiple oth...
- Mar 01, 2022
Ya, seems like the radios went bad. Sorry about that.
You have some options.
Good Luck.
Mar 01, 2022Guru - Experienced User
Be sure your connecting the WAN port of the router to your host router while in AP mode.
Power OFF the router for 1 minute then back ON?
Does the wifi seem to work or have good status in router mode?
- DarciMMar 01, 2022Aspirant
I have zero information about the modem since I am just one of the renters in this building. I don't believe there is any issue with it since the many other routers are functioning and I can see them listed as options on my devices. I don't have access to anything but my own wall port. I have never been able to get the WiFi to broadcast. Powering off and on does nothing.
I have not factory reset since the firmware update. I will try that next.
Anything else?
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
- FURRYe38Mar 01, 2022Guru - Experienced User
The WiFi is not working in either mode. The lights are on. The settings are correct. And it has not broadcasted. As a router or as an access point. Based on the lights and settings, it looks like it SHOULD be working. But the error persists.
