DarciM
Mar 01, 2022Aspirant
Nighthawk AC2300, R7000P; WiFi/SSID not broadcasting, all lights on, all settings set to ON
I purchased this router used (so that may admittedly be problem 1...). Netgear Nighthawk AC2300, R7000P. I have it for a small office in a large building with fiber internet so there are multiple oth...
- Mar 01, 2022
Ya, seems like the radios went bad. Sorry about that.
You have some options.
Good Luck.
Mar 01, 2022Guru - Experienced User
Be sure your connecting the WAN port of the router to your host router while in AP mode.
Power OFF the router for 1 minute then back ON?
Does the wifi seem to work or have good status in router mode?
DarciM
I have zero information about the modem since I am just one of the renters in this building. I don't believe there is any issue with it since the many other routers are functioning and I can see them listed as options on my devices. I don't have access to anything but my own wall port. I have never been able to get the WiFi to broadcast. Powering off and on does nothing.
I have not factory reset since the firmware update. I will try that next.
Anything else?
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
- FURRYe38Mar 01, 2022Guru - Experienced User
- DarciMMar 01, 2022Aspirant
The WiFi is not working in either mode. The lights are on. The settings are correct. And it has not broadcasted. As a router or as an access point. Based on the lights and settings, it looks like it SHOULD be working. But the error persists.
Press the reset button the back of the router for 10 seconds then release. Disconnect the router from the wall jack. Wire connect 1 PC or laptop to the back of the router. Walk thru the setup wizard with a web browser. I'd change the SSID name and PW during the setup to something unique and you can see on your wifi devices. After it's set up, check to see if the wifi is seen on any wifi device.
