DarciM
Mar 01, 2022Aspirant
Nighthawk AC2300, R7000P; WiFi/SSID not broadcasting, all lights on, all settings set to ON
I purchased this router used (so that may admittedly be problem 1...). Netgear Nighthawk AC2300, R7000P. I have it for a small office in a large building with fiber internet so there are multiple oth...
- Mar 01, 2022
Ya, seems like the radios went bad. Sorry about that.
You have some options.
Good Luck.
DarciM
Did the update. Still no dice. Thank you for your help. I hate thinking I ended up with a brick of bad radio but if there are no other mystery settings that would impact the signal, then I guess I'm out of luck.
Mar 01, 2022Guru - Experienced User
Good Luck.
