Gtfox
Apr 26, 2018Follower
Nighthawk AC2300 R700p open vpn configuration
I am trying to configure Open VPN. Have followed all instructions. when I try to connect I get the following error messages;
OpenSSL: error:140AB18E:SSL routines:SSL_CTX_use_certificate:ca md too weak
Cannot load certificate file client.crt
client
dev tap
proto udp
sndbuf 393216
rcvbuf 393216
push "sndbuf 393216"
push "rcvbuf 393216"
dev-node NETGEAR-VPN
remote Gary-PC.mynetgear.com 12974
resolv-retry infinite
nobind
persist-key
persist-tun
remote-cert-tls server
ca ca.crt
cert client.crt
key client.key
cipher AES-128-CBC
comp-lzo
verb 0
What is the solution?
Thanks
Hi Gtfox,
Please try this firmware.
https://kb.netgear.com/000057108/R7000P-Firmware-Version-1-3-2-34-Hot-Fix
- JamesGLNETGEAR Employee Retired
Hi Gtfox,
Hi Gtfox,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
