Tjrue
Sep 30, 2023Aspirant
Nighthawk AC2300 Remote access stopped working
I turned on remote access using the default port 8443. I was able to access my router remotely for a few days. However, now when I try to access the router it never connects. this was my first tim...
michaelkenward
Sep 30, 2023Guru - Experienced User
What did you actually do?
What do you want to achieve with remote access?
What Netgear hardware is this?
AC2300 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
Remote access is giving way to Anywhere Access.
Tjrue
The best I can remember is R7000p
- michaelkenwardSep 30, 2023Guru - Experienced User
I have one. It supports Anywhere Access.
PS Register the R7000P with MyNetgear and you won't have to guess what devices you own.
- TjrueSep 30, 2023Aspirant
Thanks, I was just reading about Anywhere Access. That’s what I’ll do next time I get to the location.
Thanks again for responding
- TjrueNov 10, 2023Aspirant
So I bought a device called "Keep Connect". This device works incredibly well so far. Look it up !
Basically, this device is a WiFi wall plug (power for the router) that monitors your internet connection. So, if the internet connection is lost it will cut power to the wall plug and wait 30 second (default/customizable), then reboot itself and restore power to the plug.
I have had 2 reboots in the last week and everything is working perfect.
What if your internet provider is down for an extended period of time or 3 reboots don't work? the device tries 3 reboots (default/customizable) then waits 4 hours (default/customizable) to start the reboot process again
You can also set a time interval, in days, to automatically reboot your router via a power plug off/on cycle.
