DeepC3
May 12, 2021Aspirant
Nighthawk AC2300 Smart WiFi Router drops internet output
I have troubleshot and had Google Technicians troubleshoot my internet issues on 6 occasions. I have purchased over a dozen new Ethernet cables ranging from CAT 6 -CAT 8, reset to factory settings, an...
May 12, 2021Guru - Experienced User
What gateway is it connected to?
what firmware is on the router? (hint, the latest isn't always the greatest)
did you ever try a factory reset and reinstall on the router?
DeepC3
I’m not sure how to check or alter that, and unfortunately getting a hold of Netgear support directly is nearly impossible.
- plemansMay 13, 2021Guru - Experienced User
The gateway is what modem/fibre box the router is connected to.
the firmware is what runs the router. log into the router. top right side (I think, not at home to check) of the page has the firmware version. Or the status page will.
- DeepC3May 13, 2021AspirantIt looks like I’m currently running firmware version V1.3.1.64.
- scfancherAug 04, 2021Tutor
Did you ever get this resolved? I'm having the exact same problem and its driving me insane... ha. Trying to work from home when being dropped from internet randomly is infuriating and impossible.
