golfergal
Jun 30, 2019Aspirant
Nighthawk AC2300 Smart WiFi router ethernet slot to my Sprint Rave booster is yellow. Why?
I have a Sprint Rave booster that has an ethernet cord plugged into it and to the Router. The light on the router is yellow, but all the other lights or white. Lately I have not been getting my tex...
- Jun 30, 2019
> [...] Do I need a newer ethernet cord to get higher mbps? My ethernet
> light in always yellow. [...]Perhaps your "my Sprint Rave booster" is always slow.
I'll assume that your "my Sprint Rave booster" is one of the many
"Sprint Airave" devices (about which I know nothing):https://www.sprint.com/en/support/solutions/device/airave-support-center.html
Does the Sprint AIRAVE support 3G data?
Yes. The AIRAVE provides enhanced coverage for any 3G Sprint phone
or mobile broadband card at EVDO Rev. A data speeds of up to
3 Mbps downstream and 1.5 Mbps upstream. [...]If the top speed of the gizmo is 3Mb/s, then there would be little
point in giving it a 1000Mb/s Ethernet interface. So, it's probably
always slow (by gigabit Ethernet standards).
> [...] Not sure how old my ethernet cord is, but I would say pretty
> old.The same could be said for many of us.
If you're worried about your cable, then connect its ends to any two
of the LAN Ethernet ports on your router, and look at the port-status
LED indicators. If they're white, then the cable is better than you
need.
Note: "m" = milli = 1/1000. "M" = "mega" = 1000000.
golfergal
Thank you for this information. Now my question is... Do I need a newer ethernet cord to get higher mbps? My ethernet light in always yellow. Not sure how old my ethernet cord is, but I would say pretty old.
antinode
Jun 30, 2019Guru
> old.
need.
