AlpineKid66
Oct 14, 2021Guide
Nighthawk AC2300 Smart WiFi Router (R7000P-100NAS) WHY no updates??
Firmware Version V1.3.1.64_10.1.36 as of 15 October 2021 go to NETGEAR Download Center and see Firmware/Software updates. I go to and find these Firmware updates. Download the .zip file for ...
AlpineKid66
Oct 19, 2021Guide
I do not have the money to buy a different device.
That is if one could be found since everything is on the ships on the west coast.
I take it that there are NO updates for this router.
Right?
or
Wrong?
Thank you
Oct 20, 2021Guru - Experienced User
Never said you needed to buy a new one.
Have you tried going just 1 newer version of firmware versus the one you're on?
Try the 1.3.2.124
- AlpineKid66Oct 22, 2021Guide
First went to
and did not see the firmware version 1.3.2.124.
Found it here, R7000P Firmware Version 1.3.2.124 | Answer | NETGEAR Support
Will try later today, 22 Oct 2021.
Thing is I bought this unit/device with Firmware Version V1.3.1.64_10.1.36 as of 12 March 2021 on it.
Why did Netgear not update it to version 1.3.2.124 when I turned it on?
Maybe because of COVID &/or no workers. Oh well.
Thank you for info.
