Retired_Member
May 25, 2020NIghthawk AC2300 suddenly dropped network - won't recognize password
Netgear nighthawk AC2300 Smart wifi router Model : R7000P We lost our WIFI connection and can't get it back. It does not recognize our password. I had previously blocked all new devices from getti...
- May 26, 2020
Retired_Member wrote:
I had previously blocked all new devices from getting access to our network.
Tried removing that block?
I am not sure how to change the password now, it keeps telling me the old password is wrong.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
This will tell you how to change the wifi password.
michaelkenward
May 26, 2020Guru - Experienced User
Support | NETGEAR
