lakebum2
Jan 14, 2022Aspirant
Nighthawk AC2600 R7400
My internet speed from my provider is up to 900 Mbps. On the Nighthawk app i get performing a speed test just over 400 mbps and doing a speed test over the internet just over 100mbps. Can anyone tell...
lakebum2
When connected directly to the router i get 550mbps. Its a wired connection to my Xfinity X1 router. I have checked for updates for the router and now are avaiable and im its firmware version V1.2.0.88_1.0.1 and everything you mentioned is disabled
Jan 14, 2022Guru - Experienced User
the X1 is a modem/router combo device. it can cause a double nat.
A double nat happens when you cascade more than 1 router.
https://kb.netgear.com/30186/What-is-Double-NAT
Fixes? There’s 3 options but only use 1.
1. Put the modem/gateway in modem only/pass through mode. This disables its routing functions.
2. Leave the modem/gateway in router mode but put the Netgears IP address into its DMZ. This forwards the data to the netgear. You can either leave the modem/gateway’s wireless enabled or disabled. Just make sure its using a different wifi channel to prevent interference
3. Put the Netgear into access point mode. This disables its routing functions. Wifi/ethernet still works but it does disable some features.
https://kb.netgear.com/26765/Which-features-are-disabled-on-my-NETGEAR-router-when-it-is-set-to-AP-Mode
