DavidmBaker
May 05, 2025Follower
Nighthawk Ac2600
My router does not connect any Windows 10 or Windows 11 computer via Ethernet. The port works fine for my Windows 7 computer. They have no connection issues via Wifi but I need a more stable connection for livestream.
- EduHQ_pkAspirantundefined
If it works on one device, it should work on the others. it isn't an issue of the router needing to install anything for drivers/etc when using ethernet. Its on the devices (pc/laptop) own networking protocol. so you might need to look at the driver/OS/network settings of your pc
