ryanswart
Feb 14, 2021Aspirant
Nighthawk AC3200 - secondary wifi behind Google mesh wifi point - can't connect after Google install
Have Google fiber but their original network box and wifi had terrible wifi coverage. 3 years ago purchased a Nighthawk AC3200 tri-band wifi router to help with coverage and it worked pretty well. ...
- Feb 16, 2021
you can view/change it following this guide.
How do I change my NETGEAR router to AP mode after setting it up? | Answer | NETGEAR Support
Feb 15, 2021Guru - Experienced User
Is the R8000 in access point mode?
running 2 routers on the network can cause issues.
its called a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
ryanswart
Feb 16, 2021Aspirant
Admitting my ignorance - I don't know if it's in access point mode. How do I see the settings and change it if necessary?
- plemansFeb 16, 2021Guru - Experienced User
