Brucep7
May 01, 2021Tutor
Nighthawk AC3200 Model C7800 not capable of Xfinity Voice
Hi, I'm not a "techie" and I have a question that probably has a logical solution other than just using an Xfinity modem. I bought this great modem-router and it gives great service on Xfinity intern...
- May 02, 2021
To use xfinity voice, you need an xfinity compatible modem. Getting an adapter won't work.
May 02, 2021Guru - Experienced User
You can't simple put an rj45 to rj11 adapter in and get voice. I wish it was that simple.
Options?
1. get a modem/voice device like the cm1150v or the cm2050v and then buy a router seperate. Then you'd have voice.
There is the C7100V that also integrates modem/voice/router but its only docsis 3.0
2. You don't have to use xfinity voice. There's other VOIP options. You could go with something like Ooma that is a voip service option and tends to be cheaper than xfinity voice anyway.
- Brucep7May 02, 2021Tutor
Thanks Plemans. The Oomans looks like a possible solution without having to buy more equipment (except the Ooman phone).
I came across an Ethernet phone on Amazon. Will this phone work with Xfinity Voice thru the C7800 Cable Modem?
- plemansMay 02, 2021Guru - Experienced User
thanks for quick reply. Xfinity rep told me to exchenge the Nighthawk at Best Buy for another router with an RJ11 port on back and
Voice would work. Guess they lied to me. I can't return the Nighthawk as I've already thrown away the box and have used it for 3 weeks. Damn shame....looks like I go with Ooma
