Pirates1
Oct 29, 2020Aspirant
Nighthawk AC3200 Set Up
Hi - I have set this router up behind my router/modem supplied by ATT. I let the router configure the settings automatically upon initial set up. The router is still acting as a DHCP server (I have...
- Oct 29, 2020
Pirates1 wrote:Thanks - great advice. A couple of follow up questions:
1) Does using AP mode improve the performance over the current configuration (e.g. I am losing performance with it router mode with the DHCP enabled)?----in some instances it does. If there's dhcp conflicts, it can help.
2) Option 3, can you explain the DMZ and what that does?----netgear has an article on this: https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
so I won't go over it again. many isp's router/modems have some form of this.
Oct 29, 2020Guru - Experienced User
Options?
1. Put the R8000 in ap (access point) mode. it disables the dhcp server and lets the att router control it. You can disable the wifi on the att router but you don't have to. just make sure they're on different channels to prevent interference.
2. leave the R8000 in router mode. Put the att device in passthrough mode. this is a bit more challenging as att doesn't make it easy.
3. leave both in router mode but add the R8000's ip address to the att routers DMZ.
- Pirates1Oct 29, 2020Aspirant
- plemansOct 29, 2020Guru - Experienced User
