royf123
Aug 06, 2019Aspirant
nighthawk ac3600 dos attack: fraggle attack in router logs
i have been unable to stop dos attack: fraggle attack log entries every ten seconds or so. what do i do??
- Aug 17, 2019
Well, I have found a solution. After three visits from the tec staff from ISP, two modems and three, yes count it, three different Netgear routers: Linksys EA8300!!!!! yep, half the price and I bought it at Wallmart. Bought it on a whim while still believing that my constant intermittant loss of service had to be some devious thing that the ISP coudnt figure out. It was my last ditch b4 heading to Comcast.
royf123
hey
schumaku
Aug 07, 2019Guru - Experienced User
Not much you can do to stop - these are "real" attack attempts, driven by script kiddies typically. Get in touch with your ISP so they can drill down and identify and stop (or block) at the source.
- schumakuAug 12, 2019Guru - Experienced User
While the IP can be spoofed or show up as an IP in your home network or ISP uplink, what is the IP address and port shown along with the DoS log?
- royf123Aug 12, 2019Aspirant
10.101.0.1,port 67, i have talked to my isp five times, they say its a cable problem and the cable company says it is a isp problem. The cable people have been out here three times, they say the signal is strong. the isp has given me another modum to try but its the same thing.
- IrvSpAug 13, 2019Master
Just the other day a similar thread was started, https://community.netgear.com/t5/Nighthawk-WiFi-Routers/DOS-Attack-Fraggle-attack-port-67/m-p/1786512#M136217.
Wondering if the same ISP?
