Macattack022
Aug 30, 2022Aspirant
Nighthawk AC4000 (R8000P)
I am not getting full network speeds on my LAN ports. First off the Wi-Fi works just fine, I'm getting 400up/20down (thats what I pay for), but my LAN connections are only getting 90 down. I HAVE TRI...
Macattack022
Aug 31, 2022Aspirant
Firmware version = v1.4.3.88 (Tells me im up to date)
I believe it is this one ------Spectrum D3.1 eMTA DOCSIS 3.1 Advanced Voice Modem
Model = PC15
tried that, went directly from modem to my computer, still only 90 mbps
i've restarted these two many, many times in the past few weeks
Aug 31, 2022Guru - Experienced User
What does the connection rate show for the ethernet adapter on your PC when connected directly to the modem. If your only still getting 90Mbs directly connected at the modem, then the modem connection rate isn't working right or there is a problem at the PCs ethernet adapter.
Ensure the ethernet adapter drivers are up to date.
Ensure your using a good quality CAT6 LAN cable between the modem and PC.
