Macattack022
Aug 30, 2022Aspirant
Nighthawk AC4000 (R8000P)
I am not getting full network speeds on my LAN ports. First off the Wi-Fi works just fine, I'm getting 400up/20down (thats what I pay for), but my LAN connections are only getting 90 down. I HAVE TRI...
Aug 30, 2022Guru - Experienced User
have you logged into to see what speeds the ports are connecting at?
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
If they're only connecting at 10/100mbps speeds and not gigabit, then try a short 6ft cat 6 cable. Maybe you're runs have issues on the connector ends or the cat 8 might be causing issues. I've seen devices not connect at gigabit with cat 8 because cat 8 tends to be a bit pickier with how well the connectors are made.
Macattack022
Sep 05, 2022Aspirant
So it looks like only one of the ports is getting the full gig
- plemansSep 05, 2022Guru - Experienced User
try swapping the port that is connecting on gigabit speeds to a different port. See if it switches. If it switches to gigabit, then it isn't the router. That'll narrow it for you to either a line or device issue.
