jdoc_18
Sep 11, 2020Tutor
Nighthawk Anywhere Access won't turn on
Never had a problem with remote access to my R8000P via browser or the night hawk app until Netgear brought in access anywhere. As instructed I go into the nighthawk app when connected locally, go to ...
- Sep 24, 2020
***Update***
I use a Oneplus 7T pro running Android 10. Symptoms as per original post.I installed the Nighhawk app on my partners Samsung Galaxy S10, went through the rigmorole of logging in then tried it... and it worked.
So Netgear - Suggest you app team improve their integration testing strategy... Literally millions of one plus's out there.
Disappointed in the support from netgear, will be converting to another company in future who offer more than a few days support.
jdoc_18
Sep 22, 2020Tutor
No it's still the same, I try it every few days but it just flicks immediately back to disabled. Can you help?
Christian_R
Sep 23, 2020NETGEAR Employee Retired
Hi jdoc_18,
May you provide us with the following information for us to better assist.
Router Firmware Version:
Phone Software Version: (iOS or Android)
Nighthawk App version:
Thanks,
Christian
